Stuart Frazer
I have just bought a used MDAC which was sold on the basis that the remote wasn't working. I've powered it up and the remote seems to work fine, which is good. However, the Menu, Filter and Sel buttons on the front panel do not work. The main volume control works fine, but the MDAC is stuck in variable preamp mode when I want a fixed output. I can't seem to change that without the front panel buttons.
I've rolled back the Firmware to v0.90 but that hasn't sorted it. I cannot seem to reset the MDAC without the front panel 'sel' buttons as they aren't responding.
Is there another way to reset it, or perhaps I need to delve inside to check for lose connections? Any ideas?
