Building nCores:
You'll need the following to build a pair of nCore monoblocks, my choices in spec, others choose different:
2 pcs nCore nc400 (hypex.nl)
2 pcs SMPS600 (PSU hypex.nl)
2 pcs Chassi (
http://www.19zoll.com/)
2 pcs Chassis feet (eBay)
2 pcs Furutech IEC
2 pcs Furutech XLR female
2 pcs Cardas speaker connectors (
http://www.hificollective.co.uk/)
2 sets internal speakerwire, few cm.
20 pcs M3*10 sunk screws
All screws except for IEC, XLR and feet are included.
All cabling except between nc400 and speaker connectors are included.
Five points per monoblock needs to be soldered, 3 to XLR and 2 to speakerconnectors.
Drill holes in chosen chassi for amp and PSU modules, connect provided cables, solder conns and you're set to go.
Took me a saturday from 9 to 5 to build.
Totalcost something like ~ 1700 , chassis, Furutechs and Cardas cost a bit.
My nCores here (LarsSt) - - >
http://www.audiocircle.com/index.php?PHPSESSID=bvp8d148pvkdmsdtb6o2160i95&topic=105438.560
Sonically I'd rate them as a 6-7 on 10 grade scale. Discovered some reproducable sonical errors, at least in my system with MDAC as Pre/DAC and Evolution Acoustics MMMicroOne speakers.
