Hi sq,
where do you find those curves? could you add one more curve (green) on the same graph for denon d7000 and show it again? thanks.
Hi sq,
I'm wondering: has anyone compared the sound on RCA vs XLR on the M-DAC?
I'm running on RCA, but thinking about adding a high quality XLR input to my power amp. Wondering if it is worth trying. The amp is of course not balanced.
I got quite a good boost going to balanced, I guess though the most impact will be had if your amps are truly balanced.
I use this filter for precisely the same reason as you: to try to calm down the almost unbearably bright violins. At first I thought it was my system that was too bright, but I get the same issue when I use headphones (Grado GS1000i). It's the only problem I have with the otherwise superb MDAC, and I'm hoping the much-mentioned and much-anticipated MPAX will improve things.
When I'm not listening to violin-heavy recordings, I revert to OT XD (with software A0.06).
If anyone has any recommendations how to ameliorate the situation before the MPAX reaches production (it is no longer so high on John's "forthcoming" list) , they would be gratefully received.
Hi John!
My name is Stefan and are living in sweden. I have read about your new integrated amplifier MIMP with interrest. But I can't find any website of your company Lakewest. And therefore I hope that you can inform me where and when I can buy one of those new amplifier?
None of the 'Lakewest' products exist yet - including MIMP and MPAX- they haven't been deisgned yet. So there's nothing to show and nothing to buy
Edit: I should really have said that the designs haven't been completed yet. Block elements of the designs exist in other products and concepts, but as far as John has made anyone aware here, there are no complete 'Lakewest' designs
Hi John,
Will you be at the Bristol show this yearwith the MIMP and MPAX..? I was looking at the list of exhibitors but I couldn see Lakewest.
H
Thanks for your proposal John.
I'm located in France, not far from Paris.
I will check with the retailor if it's possible or not to remplace my Mdac and revert
hluga,
thank you very much for the gift - made me smile as its malted very close to our family home on the Scottish Whisky trail....
I'll open it to celebrate the completion of the BDAC design - and complete the bottle once the MIMP PCB are issued :
Once again Thank you VERY much
John)
You're welcome. You offer post purchase service that is well beyond what anyone can expect....hluga,
John)
Oh good luck, Hluga whose also based in France did not have much luck with having his unit serviced in France.
I you have no luck, then I'll service your unit as a last resort,
John
Whats the cost on the new creek integrated? John are you behind the amp as well as the digital?
hluga,
John)
Yes it seems like if the distributor has disappeared for servicing units. My reseller stops to distribute any of its products as some 8200 CDQ cames back without servicing several months after having being sent.
Anyways my unit works as hell since it has came back from your hands
br/
MP sent
John
