JohnW
pfm member
Yes but its more related with your amplifier firmware. Have you tried to use your headphones ?
I think you missed the point..
John, any chance you can clear your PMs - don't want to post in here a nuvistor DAC question as its only relevant to a handful of us...
Jem
Just cleared out 3 spaces! Going... Going... you know what's next...
Think I got it in there!
Your lucky, as all 3 freed spaces fill within a minute...!
Due to popular request the TDAC will have Analouge bypass...
Also, After posting that the TDAC will not have FPGA's processing power - I felt that I could not let this be, so we will add a couple of FPGA's which will allow us to do more funky things later (we have few tricks up our sleeve we want to develop) - so the owners of the TDAC can upgrade there unit later (at a cost to cover the development work) - with Firmware updates that enables the FPGA's if we can improve the SQ further...
Basically the TDAC will have the best Analogue hardware I can design - and we can build up on the digital side with the FPGA's as we progress our development skills... Even in its basic form it should be stunning - but with more to come later (hopefully),
John
This sounds so exciting
Are we going to do this by ourselves, or we will have to send it back to you?
That's wonderful, I get it now. I just googled 'FPGA' and found out I asked a stupid questionNo, just a Download... you update via the USB - like the MDAC whos software is updated over the USB, you will be able to update the TDAC's hardware with a USB Firmware update
John
Where's the drool smiley ?
Hi John,
My only quibble with the M-DAC (in comparison to my point of reference, the Naim DAC), is the sense of drive and the ability to fully immerse me in the music. The M-DAC gets me partway there, but not as much as the Naim DAC. I'm guessing here, but I ascribe this to the hefty power supplies that Naim use. If this is the cause of the difference, do you have any thoughts along these lines for the T-DAC ?
Thanks,
Jan
Hi John,Jan the problem is the MDAC is not intended to work with the Naim "House sound" I don't even want to go down that road...
I think I'd want to run from an MDAC in a Naim system TBO, forgive me Pls. if I don't really want to say any more...
What happened to the Class A Mosfet amps you mentioned once?
Hi John,
I have two main systems in two different houses. The weekend system is mostly all Naim, including the Naim DAC. The week-day system is built around the M-DAC, and I'm purposely trying to make it as un Naim as possible, just to help keep my mind and options open. The source in both is the Naim UnitiServe, which gets carried back and forth between the two houses. I havn't found a better computer source yet.
In the weekday system, I'm using an NVA AP50 integrated with the volume control wide open, controlling volume from the M-DAC.
I'm not trying to slot the M-DAC into the Naim system, but obviously, I compare between the two systems. I think the NVA amplifier is the weak point ATM, lacking grunt. I'm looking for something with balanced inputs, either monoblocks or the M-AMPS (IIRC they're balanced ?), and this is where the class A Mosfet amp (Linar Audio), comes in, as it just ticks all the right boxes, but will be physically overwhelming next to the M-DAC and it doesn't come in black
http://www.linaraudio.com/en/105-features.html
Thanks,
Jan
PS. the T-DAC would replace the M-DAC in the weekday system, and my son will get a huge upgrade to his system
The TDAC will be a full size unit - so I can squeeze everything in - Black or Silver!
I am now appreciating why it has to be full sized.
Hi John so when you say the TDAC will have analogue in does this mean the TDAC will be able to control volume of the input so a phono stage can be connected?
Geoff
