jonathanmueller
Member
I've never experienced an issue like you have described - can you try a second MDAC in your system (from the dealer)?..
I really love my M-DAC and wouldn't return it. These bugs are annoying but I do not want to buy another M-DAC because it's an awful lot of work to return it just to test it.
I know this is not a problem of the M-DAC itself but of it's firmware. Maybe you could send me a new firmware so I could try it.
(Why should the M-DAC automatically set the volume to -80dB?)
Maybe it's a good idea to enable the USB module of the M-DAC just if it has successfully booted?
Is there any way to install an old M-DAC (factory) firmware with the Mac?
I tried to reset the M-DAC to the default but the firmware I installed from wikkii is still there.
