MDAC first listen (part II)
Discussion in 'audio' started by mark.king, Nov 24, 2011.
Thread Status:
  1. mavwong
    mavwong pfm Member
    Just off topic a little here as I need some help in sourcing Dali Silver Wave 4 speaker cable? Anyone know where I could get hold of these unterminated(Raw)? Thanks in advance.
  2. JohnW
    JohnW pfm member
    Good to see they have Gold plated versions - But I cannot see how they are better quality then the XLR's fitted to MDAC...
    I believe the M-PAX will result in a step improvement in the MDAC's SQ (If it does not I will cancel its release)...
    John
  3. PhilCTTE
    PhilCTTE Senior mumbler
    Hi John , just been tinkering around with my new Squeezebox Touch and there was mention of the sync link mod optical and also power supply upgrades avail.
    What sort of price are we looking at regards the power supply?
    Few pages back you were deciding on how plush the terminals were and cost of tooling for the touchmod , for me I can easily live with out the analogue outputs.
    What sort of timescales are we looking at ?
    Just so I can budget purchasing the MPAX ..cheers
    As a side note its all true what they say about the flakeyness of the SBT server , I'm only using USB drive at the moment and its dropped twice this evening. (make that 4 times now as I write this) So looks like another expense to get a server in place or new beefier nas. Sound wise the laptop via usb is still better. Playing Yes - Fragile - Heart of the Sunrise 96/24. Comparing optical vs coax as well.
    Just wondering how much of an improvement we can get from the SBT ? Have you matched the quality of computer via USB and foobar in your tests ?
    As I much prefer the usability of the SBT (excluding speed of internal server) and integration between Spotify, Internet Radio and cross fading playlists.
    All good fun experimenting with the MDAC :D
  4. Yanntoe
    Yanntoe pfm Member
    Question for those of a technical disposition.
    Hi,
    I removed my interconnect from the Co-ax 1 input of my MDAC yesterday, and to my horrow the gold "bezel" and orange socket came with it ........! Is this something that can just be re-attached (by me - and if so is this an "open the unit" exercise) or do I need to get it back to the retailer/Audiolab?
    Sorry if this a daft question, but thought I'd ask .....
    Cheers
    Ian
  5. Chronic
    Chronic pfm Member
    Really? even if there was no improvement in SQ the functionality of the M-PAX would make it a worthy investment id've thought
    Obviously if there's a loss in SQ then thats different, but if there's no loss having dual outputs & inputs alone would make me buy it, as it would allow me to upgrade to a power amp at the same time, retaining use of my sub & also integrate a turntable into my setup
    Even if you officially cancel the release i hope there will be a few units knocking about...
  6. JohnW
    JohnW pfm member
    Hi Ian,
    You can just "Re-Insert" the Gold cap onto the connector from the rear of the unit - It will just "Push Fit" back in - this is how they are assembled during production.
    As SQ has already done with his TAG power-Amps, you could also add a very small drop of super glue to Fix the cap in place...
    John
  7. JohnW
    JohnW pfm member
    I'm 99% certain that the M-PAX PSU section will improve MDAC's SQ so I'm not worrying too much, its just a question of how much of an improvment - and will the cost justify the difference...
    John
  8. adamlau
    adamlau Um...What Is Going On?
    Great feedback, will likely leave the XLR connectors alone...For now. However, it's the repeated incidents of loose RCA sockets that will have me looking towards WBT replacements for the coax inputs. Just wanted to know if it could be done, whether the design layout of the rear panel would allow for ease of replacement. If the process would be unduly difficult, then I suppose I could live with an occasional 'push fit' workaround (if need be) :) ...
  9. TimR
    TimR pfm Member
    Hi Phil, I can't make out whether it's the USB input you're finding flakey, or the Squeezebox Server software, or both?
    I've personally never tried the USB, but the SB Server software has never given me any problems to speak of (other than the crap interface - hence the addition of an ipod touch!)
    I take it your existing NAS doesn't support SB Server in any shape or form?
  10. PhilCTTE
    The internal server of the SBT is flakey.
    I've not managed to setup a seperate server with Squeezebox server software and my NAS is not upto the job to run it.
    Raising the question on whether to continue and invest with SBT external PSU and MDAC optical sync mods .
  11. The Moog
    The Moog Member
    John W,
    Not been keeping up with this thread, but I remember mention of optional stepped attenuation available through the M-PAX. Would this just be to control the input volume of an analogue source?
    I don't have any analogue sources being a long term owner of Squeezeboxen, but I thought that a similar useful addition to the M-PAX functionality might be stepped attenuation of the output. This would allow each user to tweak this for their setup so that they were always in the -20dB to 0dB sweet spot on the volume pot of the MDAC?
    The Moog
  12. JohnW
    JohnW pfm member
    Hi Moog,
    Yes - The M-PAX in standard form (without the optional Attenuator card) will keep the MDAC's digital attenuation, as you say within a "Sweet Spot" of -20dB to 0dB (over a 60dB range) - however with the optional "Full range" Stepped attenuator we could allow a user selectable option to Enable the "Full range" Stepped attenuator" for both Digital and Analogue sources.
    John
  13. JohnW
    JohnW pfm member
    The Digital Coax RCA inputs are a combined with the optical unit (A one piece moulding) so unfortunately you cannot simply just remove the RCA section...
    John
  14. jagdesign
    jagdesign pfm Member
    Still waiting for my MDAC to arrive, getting a little worried about the number of connector related incidents being mentioned here. Bit of a shame if audiolab have skimped on the connectors, shouldn't really be seeing these sorts of failures on a £600 piece of equipment.
    Out of interest, does anyone know the warranty period on the MDAC? Couldn't see it mentioned on the website last time I checked.
  15. cooky1257
    cooky1257 pfm Member
    2 years if you send the gtee card in-they're a bit slow returning your proof of purchase though.......
  16. arthur
    arthur Banned
    Two?
  17. cooky1257
    You're just weak;-)
    Those push on sockets are in need of a spot of superglue.
  18. arthur
    arthur Banned
    I meant that he's crying about a mere two reports of sockets coming off and lots off non-reports of them staying put.
    Mine haven't moved. And I haven't touched them. Just USB and one opt.
  19. JohnW
    JohnW pfm member
    Yep, that's what they really need.
    Warranty is 2 years if you return the Warranty card...
    Don't worry, they are very easy to Fix DIY (the connector cap if it comes off),
    John
  20. liszt
    liszt Active Member
    John: Any options for us guys who only want that optional attenuator that you're making, without the PSU? Don't trust other ghetto attenuators. Wonder if there's a way to fit that board inside the mdac's chassis?
Thread Status:
