sq225917
Bit of this, bit of that
I've heard it twice properly, in the same system. The first time I was quite impressed; however, the second time I was less impressed as I heard a piece of music I had only just listened to at home and found the sound to be too soft and laid back. I can't help but wonder if much of the improvement I initially heard was more down to the fact that the DAC replaced the pre-amp in that system, rather than it's absolute quality as a DAC.
You have to take into account that Ynwan is comparing the Mdac at my house to the sound of his hifi which shares no common components and only has a vinyl front end. I'd expect his set-up to be more dynamic than mine because it uses a Naim 72 and 135's which highlight the whole PRAT aspect of playback.
I'm sat here with a Weiss 202 plugged in at the minute and theres no loss of dynamics swapping between the two units. In fact the Mdac holds up its end very well indeed considering it's 1/9 of the cost of the 202. I suspect that if you hear better dynamics with your pre-amp then that's either because it's tilted in that direction or somehow a better match with your power amps.
