MDAC First Listen (part 00111001)
Discussion in 'audio' started by ti33er, Sep 12, 2017.
Thread Status:
  1. jamjar784
    jamjar784 Heavy Up
    JohnW tested HQPlayer and said he didn't like what it did to the SQ. He didn't go into much detail about which setups he tried or the DAC, but I think he tried DSD512. I agree the T+A DAC 8 DSD is excellent and there are other upsampling software options than HQPlayer which IMHO is a PIA to use although some say technically the best.
  2. dtd
    dtd pfm Member
    I've yet to come across anything quite as good as HQPlayer; Roon's own upsampling got pretty close. I have it integrated with Roon which takes some of the PITA away. You do need a very good USB connection when running DSD 512 rates though, I was astounded by the difference a dedicated USB card made. Jitter becomes much more of a problem at 22mhz+ rates.
  3. dtd
    dtd pfm Member
    Better as the rate went up. Basically the T+A is optimised for its max rates. As mentioned Roon will get pretty close to HQPlayer with its built in DSD upsampler, at a far lower system/CPU load.
    It's night and day compared to playing just plain PCM (T+A uses a different circuit path + off the shelf ICs for PCM).
  4. DimitryZ
    DimitryZ pfm Member
    You should try the UDP-205 or PJ S2Digital, both based on 9038 chip. They are not clinical, certainly not with the filter options offered.
  5. Timcat
    Timcat pfm Member
    John,
    Does this mean that MDAC2 will not have an analogue volume control?
  6. sq225917
    Tim, John mentioned provision to trim the gain with a resistor array, transformer taps and voltage steering. I'm not sure what db range that will amount to.
    hey John, what sort of attenuation range will the DAC offer to those of us who don't want a pre-amp in the way?
  7. amershamman
    amershamman pfm Member
    Will the new mdac2 be Roon ready? Might be able to live without MQA, but not having Roon would be a great shame.
  8. dtd
    dtd pfm Member
    Streamer is based on an RPi which has no problems running Roon's RAAT server at DSD 512 rates; so I'd think so yes.
    amershamman likes this.
  9. BigDog
    BigDog pfm Member
    That is great news, John, given how the DETOX was designed out of the chute. Given that I just read a review touting an aluminum vs plastic box, I can only assume that partitioned would be even better.
    JohnW likes this.
  10. JohnW
    JohnW pfm member
    We already support Spotify, Tidal & Roon with our streamer solution (for both MDAC2 streamer PCB and our Ministreamer).
    Rune here has been testing Roon (Have I got this right :) )
  11. JohnW
    JohnW pfm member
    +6dB to past -60dB with sub 1dB steps....
    sq225917 and misterdog like this.
  12. Rune
    Rune pfm Member
    Yes you finally got it right :)
    Yes I can confirm that the streamer supports Roon (it is the real RoonReady) and if you connect a screen to hdmi port. it will show the cover art from Roon in the UI.
    Personally I will mainly use Roon, but it is convenient that you can add put in USB stick/drive when someone comes over and it will scan it for music which can be played in the Volumio UI in a browser.
    JohnW likes this.
  13. Timcat
    Timcat pfm Member
    Thanks John!
  14. iansr
    iansr pfm Member
    At Munich Bruno Putzey was there with the new Mola Mola DAC (which BTW has also been several years in gestation despite them having a whole team of people and other resources). It also uses a discrete DAC. To give you some further perspective Bruno told me it will sell for 6k euros - although somebody else from Mola Mola told me 10K. I've no doubt the DD2A would cost that kind of money if it was sold commercially.
    timola likes this.
  15. iansr
    iansr pfm Member
    John
    will the DD2A have an AV bypass? If so will it link to both the RCA and XLR outputs ? Given the volume control architecture you described I assume it will not control any signal coming in on the AV bypass input ?
  16. JohnW
    JohnW pfm member
    Ian,
    AV bypass is offered as an option - RCA AV input to XLR / RCA output.
    AV Bypass has no Level control, its simply passes the AV signal to the RCA / XLR outputs.
  17. iansr
    iansr pfm Member
    thats great thanks
  18. JohnW
    JohnW pfm member
  19. timola
    timola pfm Member
    Wow! ... I was musing whether to go for the MDAC2 or FDAC ....now I'm going to get both...:D
  20. timola
    timola pfm Member
Thread Status:
