I don't know how much of the design of the physical build of the miniDAC (the Pro-Ject Pre Box S2 Digital) was down to John, but it's worth noting that it is very fine. The chassis is not flashy, or overtly decorative. But it is elegant, clean, respectable, quality, well-finished. Certainly nice enough to display. And with the ports and knobs lining up very precisely. The chassis, connectors and knob and pcb mounting are simple but solid, sound. Internally, the pcb layout is dense but tidy, with attention given to a pcb copper shield between USB input and analogue output.It's interesting that you think the chassis for the streamer is nice enough to display, as the finish was a concern of John's. ... John has high finish standards so I reckon even the below-par Detox chassis will be good enough for most...as long as the ports and knobs line up correctly.
Yes volumio was preinstalled so no fiddling with linux for those that just want something simple and get going instantly by either connection a UBS stick/harddrive or pointing to a network share.
My long term plan is Roon not Volumio but I will test it for some more days to test functionality and stability now with about 27,000 tracks added.
Think that a 2400 album library is a reasonable size to test with. Much bigger then I would use Roon or LMS.
The UI sometimes get a little unresponsive but nothing serious. Music play back has been stable so far. I have mainly played 24 high res tracks.
Yes, there are some awkward aspects to the Detox's chassis (extreme shielding), but not to the other products' chassis.
I can see that Tidan is supported and I will test that.The install should already support ROON - its not certified yet so you will get a message as such & also supports Tidal.... I'm not sure how well the ROON integration works, but its in the process of being updated to the latest ROON SDK.
I wonder how 24000 Albums works!!! Wow!
I'd be happy with double sided tape sealing my detox
But there is no reference to Roon in the UI and if it was running my Roon Server would see it, that is why I wanted to ssh into it and just install RoonBridge my self, but the default volumio user/password does not work.
Sweet! I can now confirm that Roon is working.There is a small bug that's been corrected with the new ROON SDK, the Streamer doesn’t show up in Roon unless you have the DAC hooked up to the Streamer prior to booting up.
So try rebooted with the DAC connected prior to booting up...
Sweet! I can now confirm that Roon is working. .
I think it's a plugin in volumio. maybe try the forumSweet! I can now confirm that Roon is working.
I think it is Squeezelite is the only essential features missing.
For other streaming software I think it is OK to say that the user is on there own as long as the GPIO setup and what network driver is need for building your own solution.
There is a volumio plugin for Squeezelite, look under the plugins tab.
Jem,
I only have OEM build of Volumio customized for our streamer hardware - but there is a RPi build on the Volumio website.
http://updates.volumio.org/pi/volumio/2.389/volumio-2.389-2018-03-26-pi.img.zip
if it's raining on Sunday
