DNM
The MiniDSP boxes we tried had a very negative effect on sound quality - the issue seems to be the SharkDSP sample rate converter block used to allowing a single output sample rate and which ease the filter coefficient requirements.
The SharkDSP sample rate converter sounds REALLY bad.
Which MiniDSP's did you try?
I've used a 4x10HD for 3yrs or so and don't hear any material difference running a digi feed through the unit with all the filters off to an external DAC compared with direct to same DAC.
In fact, just to pacify the audio nervosa you've planted in my head with this post, I've just plugged an RCA coax cable from my Allo Digione to my DAC and A/B'd with the BNC output via 4x10HD > AES/EBU to same DAC and there's no discernible difference. Where you get this "REALLY bad" observation from is beyond me. I also find it somewhat distasteful that a chap who has taken peoples money and failed to deliver a product has the audacity to diss another manufacturers product on a forum, especially when said manufacturer actually delivers its products and provides exceptional VFM and service.
I have had a MiniDSP2x4HD between MDAC and amp to correct room modes. The result was not very promising. Less boom but much less lively. I am back to passive room / loudspeaker treatments. I guess double DA/AD/DA is not the way to go.
Its very easy to get DSP hopelessly wrong. Without knowing precisely what your problem is, its impossible to cure it. Correcting solely by ear is futile. Measurements are essential then you can manually create correction filters or generate and upload them from the likes of REW. I'm afraid DSP gets a bad name from people that haven't applied it correctly. I almost gave up but persevered and now wouldn't be without it.
