John, so there will be two balanced headphone outputs? Does that mean you're going to supply a replacement front panel as well? And where will you find the space for the ADC board?
(Are you sure you don't want to rename MDAC2 to FDAC? )
Mark,
Sorry I corrected my original Spec. but its still shown in Tims post - the MDAC front panel is reused, so the 4W balanced XLR's are on the MDAC2's rear panel.
The same Relays that toggle the Front panel headphone jack also toggles the Rear balanced headphone outputs.
I've been asked recently for confirmation of the MDAC2 Spec:-
Dual ES9028PRO dual Mono design
x2 Optical SPDIF Input, x2 BNC Coax Input, x1 Optical Output (SPDIF/Clock)
Digital Pre-amplifier Mode
3W XLR Balanced and RCA Single Ended outputs
4W XLR Balanced headphone output (rear panel mounted)
High Current Balanced Class A MOSFET Output Stage
High Isolation, Ultra Low noise, Low impedance PSU
Front Panel mounted Single Ended 6.3mm headphone output
Galvanically isolated USB 2.0 input (internally powered) with basic Detox mode
Detox Clock-Lock support
Optional Vishay Bulk Foil Resistors upgrade in critical audio positions
DSD DAC 64 / 128 / 256 / 512
PCM DAC upto 32bits 44.1, 48, 88.2, 96, 176, 192, 352, 384, 705, 768 (KHz)
Optional RPi CM3 SOC board connected via secondary Detox'ed / isolated USB 2.0 easing software support
Optional PCM 768 / DSD256 ADC card's (Micro XLR input) - user upgradeable
Upgraded external PSU
You can either used a dummy 6.3mm Adaptor on the front headphone jack to enable the rear XLR headphone Jack (and disable signal to your main Amps) and we will also add a "Long Press" button selection (say the Mute button) to toggle Headphone mode.
That's great. May I therefore swap from the FDAC project to the MDAC2 project please, assuming that the MDAC2 will be delivered first.
Hi John et al.,
I have been a bit of from the forum due to travels at work. It is very hard to skim though this long thread.
Can anyone tell me what is the "difference" between MDAC2 and FDAC? Is the MDAC2 retaining the original MDAC footprint?
What is the price? Is it possible to jump from FDAC to MDAC2?
Cheers!
Great, thank you very much for the info!
I am not really sure I want to change, but I will keep reading about your progress, it sounds like a very exciting option too.
Same front panel / Chassis as MDAC.
GBP 500 development fee transferable from FDAC.
PCB "at cost" GBP150 to GBP250 + external PSU (say GBP100)
It will be great to meet, and that I will be able to upgrade PFM'ers MDAC to MDAC2's at the Munich show
At the Munich show we will also have a few surprises
I will probably also go to the Munich show. it will be great to meet you again and hopefully a bigger group of PFM'ers than this year.
And the $64,000 question is: when will that be?Yes sure, everyone will have that option once the PCB's are ready to go into production
I just purchased some 0.3% 3600pF Mica's from Ukraine - but styrenes have lower dialectic absorption so would be better...
Are 'salvaged' MDACs available?
