MDAC First Listen (part 00110010)
Discussion in 'audio' started by 44000khz, Aug 15, 2016.
Thread Status:
  1. wintoid
    wintoid pfm Member
    Gotcha. Is that the same quality as the main DAC outputs?
    Also John whilst I have your attention, I asked a dumb question about the MDAC. If I cable the XLR to my amp+speakers, and the RCA to my headphone amp, but I'm only using one of those at a time (the other being powered off), will I suffer lower quality? I'm assuming the powered off device shouldn't draw anything right? So should be fine?
    Cheers,
  2. fusion5
  3. wintoid
    wintoid pfm Member
    Wow, humble apologies. I looked out for a response, I really did, but somehow I missed that. Just goes to show how sometimes this massive thread can be a bit cumbersome.
    Thanks to fusion, and apologies to John for asking it twice :)
  4. ti33er
    ti33er pfm Member
    Looking at the backplate, how would the slave FDACs connect up? Thanks
  5. fusion5
    Well, the slave units require both digital data and clock sync to work.
    The digital connection is made by daisy chaining the units with short HDMI cables. Each unit will have two ports (in & out) for this type of connection. I labeled them "FDAC Slave Daisy Chain In/Out). This bus type connections is used to transport up to eight channels of hi res audio.
    To sync the slave clock to the master unit, you would have to connect the balanced clock interface to the second unit. I labeled the two SMA connectors "Balanced Clock Out". On the slave this will actually be an input. For more than two devices John mentioned a small clock signal distribution unit, which would allow for a star type connection. But I'm not sure, if that is still the case.
  6. ti33er
    ti33er pfm Member
    Thanks for that explanation, sounds a little complicated at first but I'm sure we will work it out :)
  7. JohnW
    JohnW pfm member
  8. timola
    timola pfm Member
    John, would you please check the link you just posted....it doesn't work for me...thanks!
  9. JohanH
    JohanH pfm Member
    Works for me...
  10. timola
    timola pfm Member
    Hi
    Still not seeing it....perhaps its my PC or something...thanks for checking.
    Update: I can see it from my phone...PCs are strange beasts and life's too short to understand them...so I don't care why.
  11. fusion5
  12. adamdea
    adamdea You are not a sound quality evaluation device
    A that MDac upgrade or FDac- I'm getting lost.
  13. JohnW
    JohnW pfm member
    Adam,
    Its a section of the FDAC's "Advanced Clock" added to the MDAC:-
    1. A "Test PCB" to gain "Working experience" of a important section of the FDAC design as the Superior PCB was for the Analogue stage.
    2. Offer a future replacement / upgrade for the failed MDAC Crystals (clocks).
    3. Will Morph onto the FDACLite later
    The few Superior upgraded MDAC's will also be fitted with the new Clock circuit to gain "field experience"....
  14. Jason_PFM
    Jason_PFM pfm Member
    So it seems the FDAC is not gonna happen this year, maybe 2017 or 2018 :confused:
  15. adamdea
    I see. Are you still proposing to offer the superior as a general upgrade with people employed to install it (with or without clocks)? Jirij's recent post suggested not.
  16. Discovery
    Discovery pfm Member
    Does this matter? Really...?
    Everything John and the team are doing at the moment are clear, positive steps towards the end result. The amount of R&D that is evident is possibly unprecedented for a product of this type, let alone one with a limited production run. I couldn't possibly imagine John could do more than he already is to ensure a successful outcome. The man is a perfectionist - for such people, time is their enemy; for the patient, the results are becoming apparent and are rightly celebrated. Yes, the final outcome is eagerly anticipated by everyone on this thread but it shouldn't be rushed.
    Instant gratification and relief can be achieved by visiting any number of specialist shops who will have leading-edge versions of these products available right now. Or, like the rest of us, you could choose to enjoy the journey because all good things come to those who wait.
  17. highfi
    highfi pfm Member
    And my non-Superior MDAC, too? ETA?
  18. JohnW
    JohnW pfm member
    highfi,
    As soon as the Clock PCB's arrived (due Friday) I'll fit the Clock module over the weekend and ship your unit Monday or Tuesday.
  19. JohnW
    JohnW pfm member
    Adam,
    I have 4 Superior PCB's - two are spoken for.
    The trouble with the superior PCB's is the cost - and that we are "so close" to a complete replacement DAC PCB.
    Ideally, it be better to merge our "XMOS development board", Superior PCB & Clock PCB onto one board and this becomes a direct MDAC PCB replacement PCB - reusing the rear panel & Chassis.
    On the XMOS development board I was able to design critical sections such as the Clock circuit in my CAD system and then Jarek "imported" the design into his CAD system so that I only need to design the critical sections then Jarek is rapidly able to spin a design.
    The beauty of this approach is that we can have the PCB manufactured here in Europe with a vendor I've been in recent contact with.
    The final decision comes down to the listening tests of the merged Superior + XMOS PCB and the just issued Clock circuit and what to do for a PSU - as the MDAC's current PSU solution is a limiting factor - which will become even more limiting with the mew PCB.
    If we de go ahead, then we can have the first PCB's within a month as basically all the hard work has already been done.
  20. adamdea
    Ok -so now we really are getting back to an mdac 2. Does this involve the original ess dac chip or is that being replaced/duplicated one per channel too?
    Sorry if I have missed all of this.
Thread Status:
