This is just the digital PCB with its connectors - the Analogue board is mounted above in its own fully screen enclosure (if you opt for the fully screen chassis). In fact both the Analogue and Digital PCB's are completely enclosed in there own CNC milled screen chassis - built like a sandwich, with the analogue section "stacked above the digital PCB.
This allows a fully featured Digital signal path (DSP's / FPGA / Linux ARM CPU) that does not interfere with the all important "analog" section - its like working on two different sections in complete isolation.
When you remove the top lid and then screening chassis you see the analogue board, flip the DAC over and remove the bottom lid and screened chassis cover and you see the digital PCB. The boards are connected via electrical connections that pass through the "center' of the screened sandwich construction, insuring the shortest and most direct signal path - while the digital and analogue sections are screened and electrically isolated.
The whole construction allows us to offer the most flexible and advanced features without compromising on the fundamentally important audio quality.
Having Jarek on board allows us to really expand the digital features as the Digital PCB is a beast of a design - without loosing sight of the fact that what matters most to everyone is the Audio quality
The L3 has x2 pairs of analogue inputs and both the L2 and L3 have AV bypass. The XLR's you see on the Digital PCB are AES / EBU digital "SPDIF" input (for DAC) and output (ADC) used in the Pro Audio environment, some of the first units are scheduled to be used in recording studios to capture directly from Master Tape in DSD as LakeWest "Demo" Audio files
