Exactly.
+1 Have not even finished my first cup o' joe and already my head hurts!
Exactly.
Anyone happen to know if Apple's 10.11.4 update to El Capitain released yesterday fixes issues that may affect the MDAC over USB? ....so far I'm still running 10.10 to avoid any issues, but if they were fixed it would be nice to upgrade. I've just given it a try with another Mac runing 10.11.4 and so far it "seems" OK. Can someone remind me exactly what the issue was before?
These arrived yesterday £ 5.99 inc. delivery from China !
Highly recommended, the light is now fit for purpose (LED +push button switch) even removable to use as a separate light source.
11 levels of magnification, can be worn over spectacles.
No brainer.
I have no affiliation with Laozong Gou.
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=252254461326
Just received my pair today. Have not tried them yet but they are effen amazing for the price! WAY
Laozong Gou being the Chinese for mister dog but as no one noticed....
Bob L & misterdog
Thanks again for saving me the hard (brain) work. It's never straightforward when two similar cables have different colour codes.
Having lashed up a twin Calex supply, first impressions are very positive. As usual, incremental improvements are at first most noticeable in the percussion on Jazz and R & B tracks: I haven't needed to tweak the subs down this time, but bass is tighter, cymbals better defined and the overall improvement in separation, 'presence' and drive will obviously be carried over into classical music. (From what I've read lately, it's all about transients.)
So now I have to take it apart, get a case, IEC plug, socket and fuses and build the thing properly. Just as soon as I can bring myself to switch off the music.
You're welcome, as they say. I'm very glad to have another recruit to the 3-rail community (of so, far as I know, one)
One useful point which came out of the prototype was the effect of changing 2-rail to 3-rail. Organising his was trickier yhan had I expected. The only way I could sort out to do the changeover with an SPDT switch meant using different halves of one PS ifor the 3- and 2- configurations (try it and see, and let me know if there is a better solution...). Nevertheless, the sound was clearly much better in the 3-rail configuration, confirmed by an independent pair of ears. Essentially the differences were just that there is more of what davdjt reports
in the 3- configuration.
I wouldn't bother with the comparison; I was only curious, since I had suggested this, to see if the second supply really made a difference. It does, and I'm happy!I haven't compared single vs twin supplies I'm afraid: as soon as you mentioned it, two seemed the obvious way to go. 300+GBP to power a s/h MDAC always seemed daft, but 40 + hardware was proportionate and likely to be (almost) as good. I have a slightly over-size metal case, picked up for a song ages ago, so in the absence of anything better at Maplins, I'll do some gbh to that and then respray it.
I know all about expectation bias, having fooled myself in the past, but it's very satisfying to put together something that works, and a delight to hear new things in familiar music. I can hardly wait to hear it with the Detox removing/defeating jitter upstream.
Mainly a question for JohnW Should I:
1. Used single ended outputs on the MDAC
I'm thinking of getting a Quad 306 as a "spare" power amp, and it may get used on the output of the MDAC. The quad input isn't balanced.
Should I:
4. Is there a way to modify the input stage of the 306 to give a real balanced input, as Quad did make amps for pro use based on a similar circuit.
2. Use the balanced outputs wired into RCAs at the amp end
3. Use a balun transformer - I think this is how the balanced inputs are configured on my EAR890
The Quad 306 is an "Honest" amplifier design which shares its circuit design with the Quad 240, 520, 606, 707, 909 etc. It has 1 pair of output devices and a rather small heatsink so its not really up to driving your ML ESL's with there Arch Welder current requirements!
For a small box speaker, the 306 is a great Amp.
The Quad "606" style circuit does not lend itself to be modified to be truly balanced (unlike most amplifier designs) - not only is the front end circuit rather "rudimentary" and non symmetrical, but the bridge circuit itself presents a varying complex impedance that cannot be accurately simulated on the opposite input phase.
This gains you nothing but the use of different connectors (XLR's over RCA's)...
This would work, but decent Balanced transformers are expensive, magnetics are a black art - I'm scared by transformers!... personally I'd be inclined to just use the SE inputs...
However:-
I have a few Quad 240's these are basically the 306 with larger heatsinks and PSU + balanced inputs + level controls...
After my recent experiences with the amplifiers we use in the listening system - I've designed a "simple" Amplifier that is a production "forerunner" to the Reference VFET amplifiers.
Due to lack of time, I've designed the circuit but we have a third-party designer working on the PCB - it is being designed to fit the Lecson AP1/AP3 style Tower heatsink
The prototypes will be built into cannibalised Lecson AP3's and when I visit China next month for Detox production meetings I'll work with the mechanical designer for "our" version of the towers... with the electronics being completed. I have a few "cool" ideas for our heatsink profile extrusion tooling.
These amplifiers will be Monoblock towers - with a truly balanced ClassA current dumping 150W+ (with plenty of Current) - they will be the best practical designs without the VFETs' Tube + VFET devices.... Obviously as Reference designs the VFETs will be better, but these "towers" will be full production designs and designed to achieve the best results with the MDAC / FDAC.
I can get you a QUAD240 shipped out when I send you the DETOX prototype .. you can play with these and save your funds for the Towers or VFET balance
Oh for 100% sure the Detox will solve the switch PSU noise from being injected into your system amongst other benefits
