Hopefully it will be the same 4-pole XLR connection that most balanced headphones use nowadays?
I thought that you were going to use a *male* 5W socket on the MDAC2 - sure, the semi-standard of balanced headphones using 4W female big XLR on the source side is one thing, but with a custom connector, I was under the impression that using male 5W miniXLR on the source is more appropriate (considering the "common sense" of using male/female on other outputs/inputs).I'm hoping to be able to use the 5W (pole) version of this connector - in fact the very version (5 pole) shown in the picture.
MiniXLR Female 5WJohn,
have you decided what number of pins will the balanced headphone out have? I'm ordering some stuff from farnell and would like to save on shipping - should I get miniXLR female 4W or 5W?
(5W would help with grounding the cable shield, I'm unsure how good the connector shell connection is on miniXLRs)
(I presume the ADC inputs are going to be 3W).
Thanks,
Jiri
I agree, which is why I pointed out your link of PCB-mounted 5W miniXLR *female*, instead of male for balanced headphone *output*.Jiri,
I've Emailed the company late Friday - lets see what's available in the PCB mounted type (I can buy 3W Male which is not helpful) for the ADC inputs I'd prefer to use 3W Female - and 5W Male for the Headphone output.
I'd like to keep the correct engineering convention of:-
Male = Output Signal
Female = Input Signal
Not the messed up (why did they do it???) full sized XLR which uses Female XLRs for the output signal which just flys in the face of convention for no good reason - I'm sure some amateurs started no doubt!
This might be a far out question for most MDAC owners - but as I approach the start of ADC section, I'm thinking more about an inbuilt Phono gain stage (I guess most people would like to connect there turntable directly to the MDAC2 ADC input).
If there is a slight chance I'll have the space, I might be able to squeeze an inbuilt selectable Phone stage.
If its possible (remember a slight chance) - then it would offer selectable Line / MM /MC input Gain levels (selectable RIAA and Flat for Digital EQ).
What I'd like to know what input cartridge loadings (Capacitance and resistance) are commonly used for the MM / MC ?
47K for MM and 100 Ohms for MC seems common - but what input capacitance is "Normal" ?
I've looked at Phone stage design - I've even recently bought a unit from Ebay to serve as a lab bench reference design - but I'm surprised how poorly its designed leading me to think that while the MDAC2's internal Phone stage (if its possible) might not be the last word in performance it could be better then most say 1K GBP units - with no need to mess with an external unit...
If theres no space internal to the MDAC2, then at least I'll have a better understanding for the requirements of an simple external HQ unit.
Ah John this is a whole suject in its own right there is a good paper by Mr Hagerman on this on the web somewhere but for moving coils it can vary from 100ohms to around 560 for something like Linn carts the capacitance doesn't matter to much then theres the issue of sensitivity as well very low to high output.You will need to have some way of vaying the input resistance for MC.
MM is usually OK at 47K but the capacitance is more of an issue something like 50-470pf range so this may need to be variable as well.
Geoff
Current loading (I -> V) for MC
Balanced/Floating input
Capacitance shouldn't matter - DSP eq
Just please don't forget that some of us are going to use the ADC for something else than a TT setup.
