MDAC First Listen (part 00011110)
Status
John,
I am somewhat confused. Is the -20 dB attenuation good for all applications of the Mdac? I thought it was only needed to people with active speakers...
The Analogue attenuator is just a single step -20dB attenuator which is automatically selected when the MDAC's listening level is set below -20dB.
A consideration - how does that play with the idea of synchronizing with one of your amplifiers? I remember some class A / B switch on the amplifier side when the volume got below a certain level.
Is this something unrelated to the analogue attenuator, with MDAC2 being always at full output when running with your amps (attenuation done on the amp side)?
Thanks,
Jiri
Thanks,
Jiri
Jiri,
Your 100% correct - in an ideal system the source should output at full level and the amplifier change its gain structure as required depending on level thus maximising the use of the amplifiers Open loop Gain.
The MDAC2 will disable its internal Analogue Gain scaling when it detects the MIMP / MAMP.
The MDAC2 analogue Gain scaling come into it own with conventional systems - especially those with excess gain where the MDAC is used with more then -40dB of Digital attenuation - I don't understand why they have so much gain.
John,
Its good for any application where the listening level is used below -20dB as the Analogue attenuation reduces the level of Digital attenuation required.
Let say you listen at -25dB, then the Analogue attenuation takes care of the first 20dB and then you only need 5dB of digital attenuation.
The MDAC automatically select the attenuation mode as required, so will automatically bypass the analogue attenuation for levels above -20dB, so you can still reach full the output level of 2.2Vrms.
Sit back and enjoy the ride. This is up to John. We're all spectators. John's designs and his design process have always been entertaining and simply require a little patience :)[/QUOTE]
That is what I do since I'm into this project and why I support it. It entertains me so much more than hifi magazines or stores (even more than active listening sometimes:()It puts me into an active process (without much understanding in technical issues) and I learn so much. It is also fun to read some pointed contributions of others here. And for sure I'm so very excited about an unique product with special features, developed in an ethos far beyond any industrial produced gear. We don't have so many opportunities to enjoy such in capitalistic reality. Go on John!!!
Regards,
Jansen
Its good for any application where the listening level is used below -20dB as the Analogue attenuation reducices the level of Digital attenuation required.
Regarding the -20dB attenuation on the MDAC2 side - assuming the switch is going to be software-controlled, it might be useful to allow setting the threshold value via later software updates, if possible. For example - I now listen via headphones at -16dB (balanced), which might become -19dB with the more powerful analogue stage on MDAC2, so I'd experience quite a lot of switches just by slightly adjusting the volume. This could be solved by disabling the attenuation for headphones, but then again - there are people with more efficient headphones (Hifiman?), who might run at, say, -28dB, and who would benefit from the attenuation.
This might not be a problem if the switch is done without mechanic parts and without pauses in the music (which were a consideration with the power amp, if I recall correctly).
Not something critical, but it could be useful to have it in the "todo" list for future firmware versions.
Yes - the attenuation relay is control via software - so there will be a software menu option to enable or disable the "Automatic" Analogue attenuation mode. We can also fine-tune how the Relay is controlled in use / with headphones etc.
For special uses (like Headphone only) we could offer custom output levels to optimise the listening levels - the attenuation could be set to say -10dB or some such... but really -20dB is the maxim attenuation I can apply with the MDAC2 circuit, with the -20dB attenuation, the feedback resistor is reduced to 10ohms, thankfully the MDAC2 has a REAL power output stage and takes the 10 ohm load within its stride.
Regards,
Jansen[/QUOTE]
Jansen - :) Thank you for your valued support
Ill just chime in an and say that I'm 100% behind JohnW. I'm supporting an artist here, and of course he need to have all the creative space he need, THAT will give ME the best product.
So John...Kep un dreaming and we will try to support you.
( and in the meantime ill try to decide if i relay need those b&w 801 s80, or that it would be possible to live with just my pair of Martin Logan Vantage....tuff one ;) )
Yes, inserting headphones would enable a new DSP Profile - you have the option of crossfeed or Tone controls / EQ if desired - or just totally bypassed :)
With the DSP we can also add very gentle Tone controls.... Headphone crossfeed and potentially more exciting for my "purist" HiFi nature are more advanced digital filters that could eliminate pre-ringing etc... Who knows what we will develop in the future that can make use of the on-board DSP.
Now we are talking!
Exactly! The more I think about this, the better it gets. I prefer a future-proof design.
Keep up the good work!
Michael
Thank you and everybody else for the kind words of support and encouragement.
Those B&W speakers are going to be a very different beast to your Martin Logan Vantage - Vantages seem like a very good speaker - I really miss my ESL's. I look forward to the new lab being completed so I can set-up the listening room with my CLS's or the Aeons... The CLS's are very fussy about the room - they either work very well, or they are terrible, the Aeons are much more room friendly.
Its said that ESLs are best driven by Tube amplifiers (atleast the Quad ESL's) - not sure how this pans out for "hybrid" ESL's... I suspect the Bass section is best driven by a solid state amp - while the ESL section might be better driven by a tube Amp - but you would have a hard time matching output levels between two different amplifier types and I'd guess its not a good idea to mix and match amplifiers without being able to correctly match the units gain and phase etc.
The other day I found a Quad II Classic Integrated tube Amplifier under my Lab bench I'd completely forgotten about - its a Tim Paravacini design which also has a decent Phono stage - its had only a few hours use, if anyones interested in making an offer I'd let it go cheap as I have no need for it + I'd be able to stretch my legs after all this time :p
How would it fare into 4 ohms at 90db speakers ?
I rekon she would be a beauty with an anolugue front end.
Pm. me with a price.
I rekon she would be a beauty with an analogue front end.
She has a 4 ohm tap - let me test her in the morning, if everything tests out OK, I'll send you some pics :) (and the test results) :)
Being a Tim Paravacini design she meant to be very good :) - I've only heard good things about the design - its always been rated very highly :)
Here the cheapest unit I could find on Ebay - I'd accept much less as its without original packaging... I'll first confirm that its in perfect condition both electrically and cosmetically :)
http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=301133189122
Provisionally sold then. :D
Have you tried it with your ML's ?
Qual. Cab. email may be better.
Regards Paul.
Its worth noting that while we have called the external analogue input "AV Bypass" it can also be used to connect an external analogue input, say from a Phone stage - which might have more relevance to a Pure HiFi system.
Really??? I am so excited. I don't post here much but I've read about 1000 pages and I never heard this before. An analogue "in" is the only thing that is missing from the MDAC 2. Now I really can't wait. I almost bought an Auralic Vega last week as it's getting hard to wait. I'm game for the best DAC that you can make...this year though, please!
Jim,
The Analogue input (Analogue bypass) is fixed level, so you will need a method to adjust the level of your analogue source (a simple passive pre-amplifier will do) :)
We will make an external Analogue attenuator available at a later date if your need a variable (adjustable level) input based on the extremely HQ Khozmo 48 step stepped attenuator - which will be controlled via the MDAC2.
Oh Yes - I can promise the MDAC2 will be out THIS year :)
Status
