fortunately since a demo of a bel canto tuner showed up my aeriel as no good i now have a good one and my little cyrus fmx sounds briliant but i know there is better.
now the question is , is the tubed version worth the extra or should one get the md100 ss for a few pennies more than the tubed 90 version .
biggus . yes the bel canto was marvellous and had a remote but they don`t have the `well known factor` that magnum do . i have put umpteen comments on the web re the fm1 [just google and you will see pages of my comments!!!] with little response
just put a thread about magnum and wow theres a big response from many lovers of this brand. the advantage of the bel canto is you can upgrade with a dedicated psu [the vbs1 [£1299] but that makes big total spend altho the psu can upgrade 3 pieces
hifinut, if you intend to leave the tube unit powered all the time my guess is that you will have to replace the tubes in about 3-4 months. Tubes are not expensive and you can change them yourself easily. It is just a matter of pulling them out of their sockets and replace them with new ones.
If it was me, i'd go with the MD 100 because it is just a better tuner. I have an MD Etude witch I bought 23 years ago and it is powered on 7 days a week all year long. I have never changed or repaired anything on it, not even a single light bulb! I should also say that I listen primarily to only two uncompressed FM radio stations and it is the best source I ever had.
i am advised the valves only cost about 38 quid so thats pretty cheap, after closely considering all your advice for which i am most grateful i tried to get a newish 90t but it had sold so settled for a s/h md100 . wll keep you posted how it sounds . thanks again pfm
