Somethings up if you find the E-480 bright and brittle.
Try Musical Fidelity Nu-Vista.
Accuphase is not bright and brittle, so something is wrong elsewhere that the amp is telling you about. Find that and sort it before you try to find an amp whose failings mask the problem.Hello all,
Was wondering if anyone knows or could suggest which would be the "brighter" of the two as a basic tenent:
1. Naim 282+250 or
2. Luxman 509x
I have tried the Accuphase E-480 and it was ungodly bright and brittle.
Thanks for comments/feedback.
Brgds.
Then I’d look upstream, to your source. If both amp and speakers are sounding brittle, they’re probably just reproducing the brittle they’re being fed. Beware of shooting the messenger.Maybe. But it lasted just a few days in my system before my ears began hemorrhaging massive mounts of hemoglobin. The real problem may be the Sopras but I have heard them sound good before...
What did the Sopras sound good with?
Not a fan of Naim (and, judging by your other thread, neither are you). I’d look there if it were me. The one place I would NOT look for the source of a hard and brittle sound would be the Accuphase component.Source was, and still is Naim ND5XS2 acting as a streamer into Naim nDAC (PCM1704K) powered by XPS. Frankly, that's atleast as good as a bare NDX2 if not better. Can't imagine the source is the culprit, but hey, you never know...
Only two hundred?Assuming it was brand new, did you give the Accuphase adequate burn-in time or did you form your impression of it straight out of the box? My Yamaha took a couple of hundred hours to smooth out.
I have recently bought one, and bright and brittle it ain't. Almost valve-like, I would say. That's with Tannoy MG12s.I have tried the Accuphase E-480 and it was ungodly bright and brittle.
Brgds.
1. Naim 282+250 or
2. Luxman 509x
