Unfortunately I have encountered a problem with my recently acquired LP12. I went to play a record on it tonight (probably only the 6th or 7th time I've listened to it since I got it) and noticed the Nima has come loose from the armboard. (i.e. it rotates). I have linked a short video to show what I mean:
I tried tightening the arm pillar grub screw, but as the arm base is also rotating am I right in saying the problem is actually the bolt that screws to the base of the arm, under the arm board? (i.e. that has come loose).
If so, is there an easy way to tighten it without having to take everything apart and upset the suspension / need to set the turntable up again?
Lefty
Lefty
