Chops54
Cheers SQ. I've had two motors on the Valhalla with the same results. The deck is built up now and running ok with 83 volts on the blue wire phase and 93 volts on the red wire phase. If I run equal voltages or near enough the motor will turn but a finger resting on the pulley will stop it. It was said in another thread that the voltages were 75 and 85 respectively and as I can't alter the voltage on the blue phase I've set the red phase ten volts over and it all seems fine.
