I suppose that would also depend on the floor and the particular stand you were using. A heavy coupled Mana stand would not be ideal.
Heavy, resonant and doesn't help on wobbly floors. On the face of it Mana should be hopeless!
Definitely not good when footfall problems are an issue. I light rigid stand would do a better job.Heavy, resonant and doesn't help on wobbly floors. On the face of it Mana should be hopeless!
Well footfall is only an issue for most when stomping across the room. For me, a five tier amp stand for my LP12 was a non-starter on my suspended wood floor. It works fine on a concrete floor in the basement.But doesn't sound as good so who wants that eh? :0)
Thanks for the links.Way off topic but I found this site to be interesting as I have in the last few years started using stainless steel under all my sources and loudspeakers.
http://starsoundtechnologies.com/liveVibeDetails2.php?THE-PROVING-GROUNDS-3
The thread starter has some interesting points throughout this thread.
https://www.whatsbestforum.com/thre...-products-still-considered-accessories.30911/
I imagine those vibrations get passed to the plinth to some extent as folks have mentioned different species of wood plinths sounding better than others.
What I have done is to modify a solid Linn baseboard by bolting 4 metal cones to the bottom plate corners replacing the rubber feet.
The base board is there for safety reasons, and to make the deck look 'finished'. It doesn't serve performance and does in fact make the deck sound worse. Linn can't admit this as they can't sell or advocate the deck without one but, if safety considerations allow it, the best thing you can do is to remove the thing altogether.
I'm sure a metal plinth will sound different but will it sound like an LP12? Not sure about that.
I remember years ago around 1986 I wanted to listen to a Asaka on my LP12 Ittok and my dealer kindly brought up theirs for a home dem for a week.Thought their LP12 sounded fabulous and brought a new Asaka for mine.
One thing I did notice with the dealers there was no baseboard on it and they where Linn dealers !
When mine arrived with the Asaka fitted.I was slightly disappointed as their deck did bass lines better.I did think maybe the cartridge needed more running in.But after a lot more hours it still didn't sound as good as theirs.
I raised it with them and they said remove the baseboard.Which I did and the magic came back.That was my first LP12 and the other 2 I have had I always removed the baseboard.
To my ears the sound just opens out more.
Only my observation .
I don’t know how you would know unless you tried one.The first time I took my deck to a Linn dealer for servicing, late eighties I guess, I remember them laughing and saying 'Haven't seen a baseboard in ages!'.
It doesn't matter how good the new ones are, they still won't be as good as no baseboard.
I’ll contact John, but anyone know much about this?
