david ellwood
Kirabosi Kognoscente
have you tried splitting your armcable?
it makes quite a difference!
For those of you want who may be interested in professional advise concerning LP12 set up, see: www.sondek-turntable.com/Linn, Jimmy Hughs explains the variability with arm cables and that there is no correct way to dress it. Jimmy, like Derek, has been in the game for over 30 years, and I do it like they showed me, first hand. If you think its bollocks. Fair enough. But for someone who incorrectly assumes that the LP12 has to be completely stripped down in order to change the subchassis, then, that makes 2of us that dont know what were talking about.
XX Kanwar
I find it difficult judging cable tension from a laptop viewed image- theres no depth of field. My T cable had a simple upward kink put in it with the aid of a hair dryer- by an LP12 technician of 30 yrs standing. Good enough for me....
i wouldnt split the cable past the p clip personally.
my own deck has a urika so not really relevant.
Hi John I have the S shape going in the opposite direction to the way youve done it; youre way probably also works if you say it bounces and swings freely. Youve turned the P-clip so the cable goes up. What I mean is that the P-clip is straight, the arm cable comes out the conventional way: close to the plinth, then gently going up and curving the opposite way to finish at the arm pillar. Im gonna get this sussed out with the pics at the weekend and get them to you.
Cheers, Kanwar.
Whatever Kanwar, but do try to know what you are talking about - S shaped cable dressing . It's hardly a 'tip' if it's a load of bollocks.
What a feckin' classic! A full scale bitch fight over "cable dressing". Only on PFM...... Gotta laugh!
