In countries with 60 Hz mains supplies, older turntables
may have a smaller (17 mm) diamter pulley. On these
LP12s the motor should be in the outermost position. This
is accomplished by having both motor mount bolts at the
extreme outside of their slots.
Please note:
All new turntables are factory fitted with the larger,
50Hz pulley, and thus should have one motor
mounting bolt at the extreme outside of its slot and
the other motor mounting bolt at the extreme inside
of its slot.
Both Lingo and Valhalla power Supplies use the 50Hz
motor/pulley.
Motors with 60 Hz pulleys as supplied in the appropriate
BASIK power supply kit and are not compatible
with the Lingo or Valhalla power supply.
Original Valhallas supplied to countries with 60 Hz
mains were supplied 60 Hz Valhalla boards.
