Yes I saw that arm, but it's a £25 start (inc p&p) and someone has already bid on it. Anyway I think as the hole has been re-cut, it's probably best to tidy it up and fit something with slightly more potential.
I think it's actually complete, except for a couple of mounting studs and the associated plastic and spring mounts. I assume these are generally fitted in the bin anyway. Of the two (GL75) arms that came with the two decks, I might just get one serviceable one - but the L59/70 one has the drilled headshell which apparently is sought-after. So if I bung it on ebay, I might even get the cost of the deck back!
It's a beautifully simple design with a nice solid feel about the controls and the way it works, and I know these can sound really good because I heard Vic's GL75 in a Slatedeck plinth.
The GL75 (£7.50 from the same seller) is also quite nice. It's missing the motor transit bolts, and it has a slight paint scuffing on the left-hand edge (which you can feel rather than see), but it also has a five hole idler. I am not normally this lucky ...
