[FS] Leben CS1000P power amplifier, 100w KT120
Discussion in 'classifieds' started by montesquieu, Mar 31, 2021.
  1. montesquieu
    montesquieu pfm Member
    After much deliberation, my Leben CS1000P is up for sale. This is believed to be the only one of these amplifiers in the UK. It has been owned previously by forum member Petrat (who I believe bought it new), and by David Coe of AD Audio, who gave it a clean bill of health when I traded him for it over a year ago now.
    It’s a truly wonderful amplifier, not just a glorious sound but also a heavenly thing to own. Build and component quality are simply the best there is out there. It has massive flexibility having among other features:
    • 4, 6, 8 and 16 ohm taps from the custom-wound Leben output transformers
    • Built in bias meter with current settings enabling a vast range of tubes to be used from EL34 types up to the KT120s it was designed around
    • Pentode/triode switching - with my Tannoy HPDs I prefer pentode but some have reported a great speaker match on the triode setting
    • A high quality stepped attenuator, designed to provide variable sensitivity/a match with any preamp, but also enabling bypass of a preamp altogether if you have a single source.
    • Proper 240v UK mains transformer (UK-supplied, not 230v European import)
    • Valve cage covering power and signal valves (not shown in the pictures) to protect curious pets and little fingers from heat and high voltages.
    It arrived from David with brand new KT120s, these have hardly been used, as I ran it with KT90s (my favourite tube of the pentode/tetrode family - a shade more delicacy than KT120, but just as low and tight in the bass). Within the last few months I have also renewed all of the signal valves with top quality ones (NOS) from Langrex (JAN Phillips 6922s and US-made GE 6CG7).
    I previously owned the Leben CS660P, this amplifier’s predecessor, and there really is no contest between it the CS1000P. The later amplifier is not just more powerful, more controlled and more flexible in terms of what speakers it will drive, I felt it also to be more musical - more snap, more inner voice detail, more timbre and texture. It’s also nicer looking and of course has the built-in meter to make tube rolling very easy.
    I think there is only one review, though it does get other mentions here and there. It is an extremely rare amp - few have actually heard it, especially in the UK - not helped by something of a vacuum over the past half decade regarding Leben distributorship in the UK. A new distributor was appointed in September last year so we can expect to hear a bit more from the brand in due course. Not before time.
    Review:
    https://www.6moons.com/audioreviews/leben7/1.html
    List price is just over £10k. I’m looking for £4,600. I do have the original box but I’d really rather not courier it - for now at least it will need to be a social-distanced meet up somewhere within an hour or so of Bracknell. Payment by BT or PPG.
    Specifications
    Valves
    - 4x KT120 (Output stage)
    - 2x 6922/6DJ8(ECC88) (1st stage SRPP)
    - 2x 6CG7/6FQ7 (Cathode connection)
    Output Power Stereo 2x:
    - 100W at 1kHz Pentode
    - 70W at 1kHz Triode
    Frequency Response
    - 10Hz - 150kHz (-3dB) Pentode
    - 10Hz - 120kHz (-3dB) Triode
    Input Sensitivity
    - 0.4V @ 50W Pentode
    - 1.9V @ 50W Triode
    THD
    - 0.4% (30W / 1kHz) Pentode
    - 1.0% (30W / 1kHz) Triode
    Input Impedance: 100 kOhms
    Output transformer settings: 4 / 6 / 8 / 16 Ohms
    Power Supply: 240V / 50Hz
    Weight: 23.5 kg (approx.)
    Dimensions: 45.5cm x 33.5cm x 20cm (W x D x H - approx.)
    Recommended bias current
    - KT150 65mA
    - KT120 65mA
    - KT90 65mA
    - KT88 60mA
    - 6550A/C 60mA
    - KT66 55mA
    - 350B 50mA
    - EL34 50mA
    - KT77 50mA
    - 6L6GC 55mA
  2. Natara
    Natara pfm Member
    Love to hear that pump out some Reggae through big 15" drivers.
    Rosewind, jason rockley and eastone like this.
  3. montesquieu
    Now's your chance :)
  4. RogerJW
    RogerJW pfm Member
    A rare thing of beauty!
  5. Rug Doc
    Rug Doc pfm Member
    Wow what a piece. That’s just lovely. I would love to own it, but very sadly it’s just not the right time. Very best of luck finding it a new home.
  6. Natara
    Natara pfm Member
    Well out of my price range at this time unfortunately.
  7. montesquieu
    I've been asked if there's a ding in the case: there isn't, it's in beautiful condition, it's just a shadow (my head most likely) on one of the pics.
  8. montesquieu
    Post bank holiday bump for this. From next week it should be possible to demo given changes to lockdown rules.
  9. montesquieu
    Now willing to courier if required - I have the orignal box and packing and am convinced it's safe enough.
  10. adamski505
    adamski505 Active Member
    beautiful rare amp
    heard it many times and it is stunningly musical.
    toms a gent to deal with too
  11. MikeMA
    MikeMA pfm Member
    @montesquieu I'm sorely tempted. What sort of pre-amp/source selector are you running it with?
  12. montesquieu
    Currently running it with Audiopax Model 5 (v4). Previoulsy used with an EAR 912. Into Tannoy HPDs as I mentioned.
    Petrat previously also used it with an EAR 912, as well as a couple of Shindo preamps (Monbrison and Aurigies) into Tannoy Prestige Canterburys.
  13. Rosewind
    Rosewind Lost in Translation
    A beautiful beast! GLWS!
  14. montesquieu
    Post April 12, can be heard here in the Bracknell area - call it a business meeting ....
  15. montesquieu
    Just looking on Hifi shark this afternoon .. the only other one of these amplifiers available 'pre-owned' in the world right now is in the Czech republic - priced at the GBP equivalent of £8,850 ...
  16. montesquieu
    Leben is now on hold pending payment.
    Rosewind, Vincent52 and eastone like this.
