Chris Cooper
New Member
Hello. I have a pair of leak Tl25 plus amplifiers in the process of renovation. It would seem one is an early model and one late as they have different chassis colours and different output transformer numbers. They have been rebuilt at some time with holco resistors and both have identical component values which tally with the only circuit diagram I can find online. Is this correct considering the op trafos are different. They were working and sounding good (and the same) for many years until one of the gec kt66 went bad. I have repaired the fault and have some el34 to use until I can afford another gec!! I also want to repaint them as they had been painted black, but matching the chassis colours is proving a challenge (paint names or codes for the champagne and bronze shades?) I might also look at reducing the sensitivity while they are stripped, does anyone have a recommendation for 775mv sensitivity? They had a resistive divider on the input, but I would consider reducing the amp gain if there is a cct mod available. Cheers Chris cooper
