The TL12 Plus is basically half a Stereo 20, so a lovely ten Watt push pull EL84 amp. You can get away with that into Quad ESL57s, the Leak is apparently a superb pairing for moderate/sensible levels, but the 63 wants a lot more grunt. I’d have thought a good hefty EL34 push-pull (about 35 Watts) was the minimum feasible for these.
And I guess it means that there are no suitable "classic" valve amps for me to try, since if you're right even the Leak Stereo 50 won't be powerful enough. I suppose the speakers, which date from the early 80s, were designed with solid state in mind.
A Radford STA25 would do the job brilliantly. Not cheap, though. There is one for sale on Ebay at the moment sitting at £1400, no bids yet. The Radford is however a seriously good amp - the best I have ever owned - and the sort of thing you keep for a lifetime. BTW, despite the "25" in its name, it actually puts out between 30 and 35 wpc.And I guess it means that there are no suitable "classic" valve amps for me to try, since if you're right even the Leak Stereo 50 won't be powerful enough. I suppose the speakers, which date from the early 80s, were designed with solid state in mind.
Surely the Quad II was designed with the ESL57 in mind (or vice versa)?
Oh wait, just saw it's ESL63. Ignore the above.
