You might ask on the UK vintage radio forum - they do a lot of cap restuffing there.
https://www.vintage-radio.net/forum/
Hot water didn't work at all. Will give it a go with the heat gun on the minimum setting later today, or tomorrow.
I mentioned before, the original reservoir caps might still be okay. There is no sign of leaking or bulging in the picture. You might try re-forming them (or testing them) before committing to replacement.
If you decide to go for underside mounted caps Tony, then have a look at the Kemet (used to be Rifa) PEG124 types.
Do they come in dual 32uF form? I can’t seem to google any up. I’m perfectly happy with F&T, they seem the goto for vintage guitar and audio amps.
No they don't. I thought as you were considering mounting the caps underneath the chassis then it wouldn't matter if it was a dual section cap or two individual ones. In fact two individual ones might allow for better selection of appropriate uF values for each section too. I'd still be inclined to replace entirely with two new F&T caps and get a paint match from one of the original can caps (can highly recommend paints4u if so).
P.S. Have a near complete 'kit' of Kiwame resistors from when I was buying in different types for my Stereo 20 project. If the circuit values are the same or similar you'd be welcome to them all gratis as I went a different route in the end.
Here’s a better illustration of what I have in mind. The one bolt will fix the two caps together and by pure luck holds the replacement at a nice safe distance from anything nearby.
I discovered a couple of weeks ago, thanks to Fran Blanch’s YouTube channel, that
the ‘WD’ stands for ‘water displacement’, and it was actually designed as part of the NASA Apollo-era in order to stop ice sticking to low-temperature fuel cells! It should never be used as an oil, though sadly many people do. Thankfully I now no longer expect to be dissolving wax!
