I’m confident ‘my’ end of the lead is solid, but I’d not put any money on the entry into the cap being good at all. I don’t understand the construction of this type of cap at all (I don’t even know what they are called), but it looks real manky to me!
Might just well be surface corrosion and all is fine, but I’d attack it by first trying Will’s suggestion, and seeing what happens. Then if need be desolder one end of that cap and get a reading of its value. As for fitting I think the leads are riveted to the cap.
C15? It does look more than a bit shabby. If it is suspect and anyone can point me towards a good replacement I’ll swap them out in both amps. It is awkward to get to as it is right under R5, so I don’t want to fart about trying to lift an end to test it, if it’s in the frame even slightly I’ll just replace it with new/known good. My meter isn’t great right down in the pF range anyway so I’m not confident I’d get a meaningful reading anyway. I have no idea what that type of resistor is even called, but if you point me to a vender I’ll go grab a couple.
PS You can spot some C15 crustyness in this pic:
Second a question. On your passive pre, are the two channels totally independent of each other? Or is there a connection between the left and right RCA outer ground rings?
Also, is that cap indeed 15pF or something different?
P.S. haven't been through the thread again, but have you tried changing over the EF86 input valve between amps?
Further to what John is saying, 15pF would be too small a value, it's odd how that arrived on the diagrams, 200-300pF would make a lot more sense.
The circuit I`ve been looking at gives C15 as 0.00002 or 200 pf in more normal terms. Also in series with a 4k7.
I assume that some differences may be to cater for different versions of the output transformer.
http://44bx.com/leak/Leak/Circuits/TL12Plus3.gif
