Just on a ‘trying to learn stuff’ thing any idea why I’m not reading anything on pins 4 & 4 of any of the valves? The schematic implies that’s the 6.3V. Is it a voltage across 4 & 5, or AC or something? I’d have expected to read something other than zero.
The heaters are as stated 6.3 volts
AC. You need to check from pins 4 to 5 of the EL84s and EF86. The ECC81 is different, measure from pin 9 to 4 and 5. (4 and 5 are soldered together in the TL12+.)
If you look at your amplifier the heater wires are the doubled green and blue wires. (As the heater winding is centre tapped to the chassis, you will measure 3.15 volts AC from the chassis / ground to either of the heater pins.)
... The pin gripper fork of pin 4 of the ECC81 tube socket just fell apart as soon as I touched it with a pin to try and tension it. These sockets really are utter crap!
So, how do you get the forks out of the socket? I’m assuming thoroughly desolder it, unbend the back tag bit so it is straight, and then it will come out the top?
Pin 4 failure of the ECC81 does exactly account for your initial faulty voltage readings. It would mean that the heater in the first half of the valve would not come on, so that half would not operate / draw any HT current.
Actually pin 4 is one of the easier ones to get to. Just remove R10 before you start and put it back after.
You remove and replace them just as you say. Remove
all the old solder, straighten the pin so it is vertical and in line with the slot in the holder and push it through from the wiring side. Make sure you get all of the old fork out before you fit the new one.
Push the new one in then bend it carefully to match the original shape. Give the tag part a good clean before you try to solder it.
You will find pins 4 and 5 soldered together on the ECC81 which might make it a little more difficult to unsolder them.
Personally I would replace both pins here. If you decide to do that you can cut the pins off with side cutters, carefully just below the wires, and push the remains out with a pin or jeweller's screwdriver. Then it is much easier to unsolder the bits of the tag from the wires. 'In free space'.
When you have replaced the pins, before you solder the wires back on put an old valve in the socket first. That will align the pins in the socket correctly and keep stress to a minimum.
If you want to practice / mend the amp before you get the new sockets, both the EL84 sockets have 'spare' pins on 6 and 8...
