the orig bulb is still in the spring, i broke the glass trying to remove with big pliers ( i dont have tools) but purchased a cheap pair of small long nose pliers, will spray WD40 on before trying to remove when pliers arrive.
Being clueless about watts volts etc wonder if this will work ****
2x LES Miniature Lamp Light Bulb : 6V 50mA : 5mm : E5 : 1st CLASS POST | eBay
i bought a lamp holder purely for backup i could get my cousin to solder the orig 2 wires that attach to current spring type holder.
So will remove orig broken bulb hopefully and put a 6V bulb in just long as it is visible/glows, it does not have to be super bright etc blah.
**** if these can work then im not too worried about bulb longevity, The bulbs is too tightly in, to remove by hand and without proper pliers is inviting trouble as i have seen
Compounding the problem i have Three Leak Stereo 70 and a Delta 70 ( virtually identical) just cosmetic faceplate change slightly bigger heatsink at rear. All the globes work, as the amps.
I started with one amp loved the sound and power. Musical to my ears especially thro a selection of Rogers LS1 & LS2 etc warm sound pretty clean without spending LS3/5 or Quad prices.
