foxwelljsly
Me too, I ate one sour too.
I currently have my sub connected to a class D power amplifier via the high level connection.
The negative cable is floating and the device is earthed via an rca cable between the LFE socket on the sub to a spare input on my passive pre and it works to perfection. This is the documented high level sub connection method for Class D amplifiers.
I stopped using the same sub with the stereo 20 and the usual high level connection configuration after I had a lot of hum.
I am curious to try this floating negative sub connection method with my Stereo 20 to see if it fixes my hum problem.
However, as I know nothing about electronics, I don’t know if my amp will my amp blow up if I do.
Will it? Is this worth trying?
Cheers
Cheers
