Hi All,
Having recently moved and unpacked my QUAD II amplifiers (New Classics, not Originals), I found that one of the KT66’s did not fair well from the move. I am now trying to source a new set of four KT66’s. It wasn’t a simple fracture or breakage that can be attributed to the removalist. The tube shows no sigh of external damage so I can’t claim insurance on this one. I suspect that vibrations or shock may have internally dislodged a heater mounting bracket or dislodged the heater coating which caused a short in the heater, thus causing it to overheat and fail. Thankfully the amplifier checks out fine with no problems mechanically or electrically.
However with the current world situation, Pandemic and international boarder tensions etc. Here in Australia, reliable sources of KT66 tubes are not easy to find.
The tube that failed was a JJ’s KT66 and I cannot source another set of these within Australia. The original Tubes that Came with the amplifier are the QUAD branded as KT66.
However looking closely, the original tubes do seem resemble a 6L6GC.
Both tubes have very similar specs and appear to be interchangeable with the 6L6GC drawing slightly less heater current than the KT66 and the KT66 having a bigger "Coke bottle" glass envelope.
The 6L6CG is used in allot of guitar amplifiers so is a popular tube amongst instrument amplifiers. Purchasing from an instrument amplifier establishment means that it is a little more realistically priced as musical instruments don’t always operate on the peculiarly esoteric pricing structures of high-end audio. I intend to replace all tubes in both amplifiers as the JJ’s have done a few hours so cost can soon accumulate.
On paper this swap out should work fine as either tube is being operated well inside the maximum conditions listed on both data sheets.
What do you guys think?
Has anyone tried this swap out already?
Regards
LPSPinner
Regards
LPSPinner
