Big John
After Mark the Ming (Mark Manwaring-White) improved my Leak/Paravicini Troughline stereo tuner I thought about the aerial.
I should explain my situation; I live in a top floor flat on a hill in North West London, there is no possibility of an external aerial, the communal one is OK but not for a Troughline which needs more signal,until now I have used a 5 element Antiference aerial in the loft. We have bought the loft and are going to add a couple of bedrooms etc, so it had to go.
I remembered an article By John Linsley Hood about a "Quad" aerial similar to those used by radio hams(apparently) I made the aerial from 4x 1' X 3' 1 MMM mild steel sheet with 1' cut off one of the panels as per the article shown at the end of his piece.
The JL hood aerial at 1 mm thick will fix flat to the woodwork of the roof under future insulation and wall board
I was charged £15 for the metal & £19 for cutting to size.
I put it together using heavy duty pop rivets with small PK screws for a 1/4" perspex panel to stiffen the 1" gap (see drawing in the article) I used 2 brass solder-less nipples soldered to either side of the gap to hold the WF 100 co-ax.
I have placed the aerial in the loft propped up for now it has not been optimised and already is an improvement by a margin for the carefully optimised 5 element aerial.
No hiss from the Troughline
http://www.mediafire.com/view/?sz8qxtc414666xu
