It's a loudspeaker Paul.
Loosely based on the JBL K2 9800. it is an active 2 way, 15 inch JBL ME150H bass/mid crossed(for now) @800hz 24LR to a JBL 2452H compression driver with Truextent 4" Beryllium diaphragm on a Birch ply/mdf reproduction h9800 horn.
Sensitivity is 97dB/w, the curved sided enclosure is mostly 25mm mdf extensively braced, has a 60mm front baffle, rear ported, 150L tuned to 30 hz.
The horn throat was modelled in SolidWorks then cnc milled, the rest of the horn was constructed from layered birch ply planed and sanded to a template. Front and top are finished in leather, side panels are American walnut.
