notevenclose
Don’t seem to be any used 240v TL5 around at the moment, 1 TL51XR and a 51XZ present on eBay, not sure what the distinction is there.
F*** knows. ;-)
As with many Japanese manufacturers, CEC's product naming is pretty impenetrable. They do tend to recycle the same product numbers with minor variation. Products are typically in the range for at least 10 years, so I suppose some minor tweaking along the way is always likely.
The TL51X is the transport, the 51XR is the integrated player with DAC. Both use the same transport mechanism. There was an older, essentially similar model, before my time really, the TL5100 series. I'm not sure where the 'Z' models fit in, again it's a suffix they've recycled from time to time.
I suspect the model changes often reflect changes to the DAC chip employed, DACs are not their area of expertise and are typically 'bought-in' or at least delivered via hired guns. When I had my DX71 II for instance, that was designed by Carlos Candeias, who went on to form BMC. Some of his ideas were deployed throughout the range, normally identified by the ever popular TLA (three letter acronym) eg. 'LEF,' etc.
Seems they parted on good terms, BMC use a transport drive which may look a little familiar, along with the 'SuperLink' reclocking option. http://bmc-audio.com/index.php/bdcd2-playertransport.html
The newer CEC DACs use either ESS chips or technology licensed from Thrax Audio. None of this is relevant if you're just buying a transport of course.
The nomenclature has become a little clearer in recent times, TL prefix now designates only a transport, CD is an integrated player, and DA denotes a DAC.
Current models to focus on I'd suggest are the CD5, TL5 and TL2 (the latter a lot more expensive). These are the first to employ a new generation drive mechanism and laser assembly essentially produced in-house. CEC's expertise has always been in mechanical engineering, they did start off as an OEM turntable manufacturer.
http://www.theaudiobeat.com/highend2017/highend2017_cec.htm
