MJS
Technical Tinkerer
I know this is better off served in a car forum but it's a specific issue and someone here may have fixed this and can tell me if it's worth doing myself.
Problem: Heater blows only cold air. This is a bit of an issue right now.
Temporary solution: Resetting the heater flap stepper motors using a long sequence of button presses.
Apparent solution: Re-fix motor spindles to their flaps so they don't slip.
As far as I can tell it's *just* an issue of removing the glovebox then applying superglue in the right place once I have access to the heater console and motors. Has anyone got one of these and had to fix this?
