Thankfully I'm in Canada so this is perfect. Is there a pinout?Depends on what pre-amp you have, but this works for NAC32 / 32.5 / 72 type pre-amps.
Get 4 of these (2 per board you want to bypass) -
https://www.mouser.ca/ProductDetail/?qs=sGAEpiMZZMvT7Of4ktfHLtSyJ6UF2bX4k%2bRf7wp1HsM= (It's a Canadian website but I'm sure they are available locally somewhere near you) and a few inches of 20AWG ish stranded hookup wire, crimp or solder to make a couple of jumpers and if you want to get fancy put some heatshrink on, remove the boards and push your jumpers onto the input and output pins of the motherboard for the boards you removed, info on which pins are the input/output pins to jumper out is easily findable on the www coz I can't post a picture - et voila - job done. Just make sure you don't jumper the +24V/GND by mistake.
Wire wrapping is an option too, but you need the exact wirewrap tool for the pin size and the specific AWG solid wire you want to use, not many people have these tools or wire at home. Using the pins I suggested and making a couple of jumpers is much easier, you could also solder direct to the pins but then it'll never be "stock" again.I suppose wire wrapping the pins would suffice? I want to be able to undo it down the road. I am using a nac 42 if that's any help.
You should be able to figure it out from this - https://www.canuckaudiomart.com/details/649304488-pcb-naim-326/images/1342993/Thankfully I'm in Canada so this is perfect. Is there a pinout?
Yes for shoe box and wide box pre's up to the end of the olive line. RSL have them for shoe box pre's but I imagine there's a bit of a problem for the wide box pre's since the connectors are no longer available.
I heard a rumour that Kit was offering 5 series phono cards (which would interest me) but I don't see how that's possible if the connectors are now made of unobtanium.
There is a thread on here where a fish spotted a source for, I think, the tin plated version of the same connector. Not sure if that is what Kit is using or not since I am a shoe box kinda guy.Yes for shoe box and wide box pre's up to the end of the olive line. RSL have them for shoe box pre's but I imagine there's a bit of a problem for the wide box pre's since the connectors are no longer available.
