jonnoshore
physicist, engineer and healer
I have both these great little amps... the 3X is currently driving my Naim IBL's passively.
I also have a redundant NAXO2-4 plan brewing...
My plan is to go active in system 2...
Question about Ion Obelisks... I'd like to use the preamp section of the 3X but take it out of the amp into the NAXO then feed it back in to 3X to power either bass or treble, the 3 with do the opposite drivers. I wanted to do it like this as the 3 and 3X may have slightly different sound so need to maintain channel balance. The pre amp stage of the 3 will be redundent.
I assume I just sever the links internally from the pre and power boards in both amps and use the pre-power connections on the back of the 3X and the power on the 3.
3X pre > NAXO2-4 > 3X power Bass
.........................> 3 power treble
Comments?
Comments?
