Internal hook-up wire for Naim
prowla
Does anybody know which brand of wire is used for the audio connections inside Naim kit (or a suitable alternative)?
I guess my google foo was low, I even put the farnell code from a reel I have and that wasn't recognised on the farnell site.
Pete
Just get the cheapest, like Naim do.
Pete
Ah yes, but then they sprinkle the cables with pixie dust, which produces a magical transformation.
I had one of my DIN-XLR interconnects apart recently. Three cores, insulation colours brown, light blue and green/yellow diagonal striping.
I'm sure I've seen that colour combination before, but can't place it..... :p
That'll be the 'signal lead' that comes with a 250. Do yourself a favour and dump it - 3 core mains flex is a poor signal cable. I use a 4 pin black sniac with a DIN to XLR adaptor at the amp end. I think Witchhat sell a dedicated screened IC for the job.
Mr Tibbs
