this would need to be KEPT at 100 degrees C
in this house i dont see any.benefits of hard water,
We have very hard water which has destroyed numerous water appliances over the years.
they are instantaneous no stored water.
'Scuse my higgorance, but how can cold water be heated instantaneously? Are there domestic nuclear reactors nowadays?
we were going through kettles in about 2 years - destroyed numerous coffee machines. Our machine remineralisesOur kettles last 4 or 5 years at least
I've lived in two hard water areas (Ramsgate and Norwich) for 40 years and believe that the minerals contained therein are medically beneficial.
Sounds extremely dangerous to me. 100degC in a tap next/near to normal taps? Make a mistake and it's A&E for you. These devices are fads imo; what's wrong with a decent kettle? We use a nice Bosch one, which will also heat just to 80 or 90, if the drink requires. Very quick.
I bought a quooker about a year ago with boiling water and chiller. Boiling water is a cheaper option to boiling water in a kettle as kettles waste unused boiled water. Chilled water is just a substitute for storing water in the fridge, although I find I now drink more water.We will be fitting a new kitchen in a few months and considering the above. TBH really only need normal hot and cold plus the 100c element. Are they any good? We live in a hard water area if that is relevant.
It is likely the poor taste is due to lack of maintenance. There should be an in line filter which needs to be changed according to manufacturer recommendations.I've been offered a cup of tea (I only drink green or white tea) made from a quooker, bloody disgusting it was too, went straight down the sink. I've never seen so much limescale in the cup and it stunk of chlorine. I do live in a very hard water area but I make my tea at 90 degrees and the wife descales the kettle as required.
Green tea should be brewed at 80 degrees as hot water 'burns' the tea. We have a small kettle that will brew to a programmable set temp.I've been offered a cup of tea (I only drink green or white tea) made from a quooker, bloody disgusting it was too, went straight down the sink. I've never seen so much limescale in the cup and it stunk of chlorine. I do live in a very hard water area but I make my tea at 90 degrees and the wife descales the kettle as required.
Eh? People have been using ascots for years to do just that.
