vln
Shuns mooks. And MQA.
Can someone enlighten me?
I got about as far as
1) "The output impedance of the preamp should be as low as possible"
2) "The input impedance of the power amp should be as high as possible, preferably above 10 kOhm"
The way I understand it so far is that the power amp needs to be as 'responsive' as possible, which is why its input impedance should be high (correct me if I'm wrong), but why does the output impedance of the pre need to be low? Something to do with damping?
I am looking around for a new pre, and two of the candidates are the ATC SCA-2 (quite pricey though) and the Benchmark DAC1 (the sensible option).
The output impedance of the Benchmark ranges from 43 Ohms to 425 Ohms (depending on the attenuator setting), for the SCA-2 it's 15V into 600 Ohms, according to a HiFi Plus review.
How does voltage suddenly get into this? And 15V strikes me as quite high?
For the ATC speakers, the input sensitivity is 1V and the input impedance is > 10kΩ (according to the ATC website), so seems to meet criterium 2 from above.
Cheers,
Samuel.
Cheers,
Samuel.
