dadgad
Happy New Year to all!
Here's something I hope you can all help me with as I contemplate 2016 purchases.
I have a good vinyl sound coming from my system at present - its an 80's LP12 with an '84 Ittok. Its currently at Cirkus spec with a Lingo 3 and was professionally set up last year. It has a Linn Klyde cartridge which feeds the MC board of my vintage Meridian 101 pre-amp. The set-up and the Lingo made everything faster, with cleaner and deeper bass, and more detail on vocals and strings.
The deck is well sorted and sounds good, but I probably will need a new cartridge at some point - its quite old although lightly used. Being very critical, there is a slight harshness on some vocal tracks on loud crescendos in rock and large scale classical - perhaps tracking limitations? Some people would say I should get a newer tone-arm (an Ekos or a PU7), while others might suggest a new sub-chassis or a dedicated MC phono stage.
So I wonder what I might get from any of these changes, and what to listen for. What could I hear from
a) a better/newer cartridge
b) a better arm
c) a new sub-chassis
d) a phono stage
I'm less interested in recommendations - 'You must buy an XXX arm, it totally trashes the Ittok'. I'm more interested in what you heard - 'when I put a new phono stage I found the sound stage widened and female voices became much more natural'
Rest of system is Meridian 506 CDP, Benchmark DAC2 HGC, Meridian 101/103D (serviced last year), ART Neo 8 speakers, in a large 25' x 15' x 13' room.
b) a better arm
d) a phono stage
