So, now I had it for some time.
It significantly improved the sound of my phono stage, from SQ point of view this must be best spent GBP40 for a hi-fi item. Ever. The difference is much bigger than adding a HiCap for example.
But I'm having a very weird issue with it:
From the start I had buzzing type of hum when I touched the head-shell fingerlift. There was also same kind f buzz/hum for a few seconds when I switched the amp on or off (NAP140/NAC72).
I've changed the cartridge yesterday (from Ortofon Cadenza Red to AT95E) and the issue is even bigger - I expected it would go away, because AT95 has plastic body, so touching fingerlift should have no effect.
But now there is same buzz/hum all the time, very slight though, so it doesn't affect listening to music, but, superweird, it gets very loud when I come close to the cart with my hand, not even touching anything!
Probably a faulty unit, one of so many. I've contacted the seller and we'll see how this gets solved (or not).
