Ideas for a speaker upgrade?
Discussion in 'audio' started by JezmondTutu, Dec 12, 2021.
  1. JezmondTutu
    JezmondTutu pfm Member
    I’ve recently switched from six years of running Event Opals back to my ‘spare speakers’ which are Epos ES14’s.
    There is an inherent musicality to the Epos’s which is not there to the same extent with the Opals. Don’t get me wrong, they are fantastic (amazing mid range, bass is more powerful and probably more detailed too), but I think it’s probably just that studio monitor thing, you hear so much but it lacks a little PRaT compared to my passive system.
    The Epos’s are superb in many respects and the amps seems to be a fantastic match (never heard ES14’s sound this good) but I’m interested to hear how something more modern (and of course far more expensive) might better them. I may try to get to listen to Kudos & ATC (SCM40’s?). Speakers need to be either oak or black and be wife friendly!
    I sold my dream speaker (Shahinian Obelisks) as her indoors hated the look of them. Have previously had Naim SBL’s (sold as they didn’t work in my old room), Shahinian Compass, Ruark Talisman 2’s, Dynaudio Contour 1.1’s and Neat Petites.
    Oh, system is LP12, Avondale TAPS, TA Plateau, Karousel, Aro, DV20XL into a Brinkmann Fein plus a modified Node2i into a Weiss DAC202. Amplification is Avondale Grad One + TPX2 and a ‘ZAP250’.
    Thanks Jez
  2. david ellwood
    B&W 803 d4 is really special if you can stretch to a pair.
  3. JezmondTutu
    They look hideous David and £16,000!
    Big Tabs likes this.
  4. david ellwood
    Have a listen to a pair, admittedly the acoustics are better then their aesthetics.
  5. JezmondTutu
    There is no way they would get approval David, they also look huge? Have to say, I’ve been unimpressed with B&W speaker’s and I have heard some very similar looking ones in a high-end system.
    Enrae8 and Darren like this.
  6. Woodface
    Woodface pfm Member
    Try active ATC’s, does your Dac have balanced outs? Active 40s are £7400 now but you should be able to get a good pair 2nd hand for circa £4k. No need for power amps, I think they are excellent.
    I’ve had SBLs, they did work on my room but ATC40S are on a different level.
    JezmondTutu likes this.
  7. JezmondTutu
    Thanks Woodface and the sort of reply I’m looking for!
    My DAC has balanced outs and also variable output. I ran the Opals without a pre as just switched XLR’s - the Fein has a volume control.
    AudioT in Brighton said they preferred passive (with Naim amps) to active 40’s, I think this is perhaps unusual?
  8. Amber Audio
    Amber Audio This is the Day
    Have you considered ProAc? Tried lots of speakers over the years and keep ending up back at ProAc when I’m after stand mounts, I use a REL Sub but they are really good without on decent heavy stands.
    The latest B&W 804 didn’t float my boat when a mate had me over, the amp was a 300DR. I use Logans in my main system but they are not to everyones taste - looks or sound wise.
    cnocmoy10 likes this.
  9. JezmondTutu
    I’ve heard Tablette 2000’s on the end of my system before, but nothing else. I’d say they weren’t too far off my Dynaudio Contour 1.1’s. Heard bery good things about Martin Logan, hadn’t considered them as an option.
  10. Woodface
    Woodface pfm Member
    ATC say their speakers sound better active, Audio T probably like to sell naim amps so…
    I have no axe to grind here, I replaced a naim CDX/XPS2/252/sc with an ATCCDA2 , my system doesn’t sound worse; quite the contrary. I reckon active operation has the biggest effect on the sound, you may not like it of course?
  11. JezmondTutu
    Yep - die hard Naim dealers. But also ATC stockists. I’m more inclined to believe you but clearly need to audition some!
    Woodface likes this.
  12. Amber Audio
    The Contour 1.8Mk2 were really good way back but I need stand mounts these days, I did consider Special 40's but am now settled on finding some used ProAc DB1 for that system, currenlt using ProAc 115.
    My main rig is a Class A intergraded into ESL11a, if you've not demo'd Logans or Maggies I'd defo try to, I love what panel speakers do.
  13. JezmondTutu
    The Contour 1.1’s were the compact stand mount.
  14. Moonbuggy
    Moonbuggy pfm Member
    How about Boenicke W5. Tremendous 3 way sound that defy the laws of physics on thin, wobbly stands. Go figure.
    I slipped a pair into my system and my missus loves them, as do visitors. I managed to get away with the premise that being small, they were a downsize in stature as well as cost from their predecessors.:eek: Reassuringly expensive.
  15. Amber Audio
    Never heard/had the 1.1 or 1.3 just the 1.8 floor-standers, nearly went up to the pretty expensive Contours but ended up with a Kef Ref 5.1 system as I was more into AV at the time.
  16. divedeepdog
    divedeepdog pfm Member
  17. maccar
    maccar pfm Member
    Harbeth SHL5+ XD
    Mac
  18. JezmondTutu
  19. Subito
    Subito pfm Member
    ProAc and ATC were the two brands that immediately lept to mind for me, looks like others had the same notion.
  20. Tarzan
    Tarzan pfm Member
