Good for you- what you like is what you like- happy listening.
After listening to both I must say the NAD sounds more lively. There seems to be far more punch too.
It's not really a fair fight. The power supply in the NAD is almost the size of the entire Brio. On more suitable speakers like the NHT SuperOne the brio really can sound great. Even with music that is more lively. In the case here I am using rather hard to drive Totem speakers.Your experience with the Brio reinforced my belief that Rega's lower range integrateds are more suitable for mellow music where grip, punch and dynamics take a back seat.
Well kind of, but it was pretty old when it died. You are right though because in trying to get the NAD M3 fixed I contacted a well respected amp fixer who did Naim/ Exposure servicing and they said "too complex for us". (I can quote from the email) I guess because it isn't a 1950s design, if only there was a UK service centre I would still have it; but then I wouldn't have discovered the AN SET!I think the biggest gripe against NAD is build quality and reliability; the comments above tend to validate the concerns about the latter.
I have a 1984 NAD 3120 that works fine still. My NAD C 316BEE from 2010 still works too.I think the biggest gripe against NAD is build quality and reliability; the comments above tend to validate the concerns about the latter.
Can I ask where this telly repair shop is? I have a couple of old amps that need seeing to that I'm loathed to spend hundreds on.A tiny bit of the email:
We have "downloaded the service manual and had a quick look and this is one bloody complicated amplifier! It will be maybe 10 x as difficult to fix as something like a £6K Naim pre and power.... For these reasons we are loath to take it on, but, will so long as you can agree to the following terms"
Now this is 'bloody complicated' because it was designed as a swan-song by Bjørn Erik Edvardsen so it wasn't going to be some old re-tread.
The funny bit was I took it to my local telly shop repair guy and he fixed it for £50 Now if you are thinking 'some bodge' my current AN amps lost a channel and he contacted AN and got the right valves, never even asked him to.
I will pm you tomorrow.Can I ask where this telly repair shop is? I have a couple of old amps that need seeing to that I'm loathed to spend hundreds on.
Ken Kessler liked his
