gustav_errata
I know, I know, another hum thread. This time it's about two active studio monitors. (Edit to note: sorry for the long post but I wanted to provide all possibly relevant details).
In my office/home studio, I have a pair of Focal Shape 50 studio monitors. These have two inputs, each: one balanced XLR and one unbalanced RCA. According to the user manual, "You can connect up to two sources to each loudspeaker using the two inputs available. Both inputs (XLR and RCA) are active simultaneously. In order to draw the greatest benefit from this feature, we recommend switching on just one of the two sources to avoid undesired signal noise." The RCA inputs are not connected to any source. The monitors have fixed gain (which differs by input), so the only onboard controls are EQ related. The monitors are on Isoacoustics stands, so can reasonably be considered to be isolated from external vibrations.
The monitors are connected via the XLR inputs to an Audient Nero monitor controller, which, for all intents and purposes here functions as a preamp. It has two sources connected: my PC's USB audio interface via balanced connection and a Primare Prisma NP5 via coax spdif to the Nero's built-in DAC. The NP5 is always powered on, the PC is only powered on when in use (but its PSU remains switched on).
All devices are connected using the manufacturer-provided mains cables to the same bog standard Belkin surge-protected-but-not-condituoned mains block.
Both monitors hum at the same frequency. I can hear a low hum from the cones but not from the passive radiators on the side. If I put my ear to the side wall though I can hear the same hum with higher harmonics. These are very quiet, mind. The internal hum can only be heard with my ear to the wall. The cone hum can be heard clearly from a few centimeters but I can still sense it from my listening position 80cm away. When I turn them off my whole body relaxes from the absence of the hum. Another note: when the monitors' automatic standby function kicks in, the hum stops.
Here is what I've tried, all without success:
Can anyone else weigh in with insights on other things to try that I might have overlooked or on the shorting plug question?
- Different room: these used to be in a different room, albeit probably on the same circuit/radial/spur/whatever the correct term is
- Unplug all devices from the mains except one monitor
- Disconnect the XLR source from the monitor
- iFi DC Blocker, for removing DC offset
- iFi Ground Defender, for removing ground-related hum
- Both iFi gadgets at the same time
