Hi guys, I bought an OLED TV last October and love it but at the moment I have the TV hooked up to my Yamaha reciever & stereo speakers via an optical cable and frankly the sound is okay but I don't think it's much better than the TV's speakers which are a 2-1 set up so I've decided to go down the AV/Integrated amp rabbit hole so I wonder if someone could advise which integrated amp with a HT bypass would be suitable for driving my Elac BS-312 speakers?
I currently have a Yamaha stereo receiver a RN-803D but unfortunately it doesn't have a pre-ins or HT direct etc and I'm not sure that it's actually capable of driving the speakers properly so I'm going to buy an AV amp with pre-outs and an integrated stereo amp either the Audiolab 600A or the Musical Fidelity M2Si obviously I'd love a Rega Elicit-R which would likely be prefect but it's a bit out of my budget.
Feature wise the Audiolab appeals but the MF seems a great amp with better numbers but less features ie no headphone socket or digital inputs etc.
Anyway my speakers are a difficult load they have
Sensitivity: 87 dB at 2.83 v/1m
Nominal impedance: 4 Ω; minimum 3.4 Ω @ 280 Hz
I don't want to throw £600 at an amp if it isn't up to the task of driving the speakers so I would be prepared to go for any other amp with a HT bypass that has the ability to drive the speakers properly.
I'm also considering moving on the Elacs and buying other front speakers and a centre speaker and surrounds (probably Elac too).
I also have the Elac stands but I don't use the stands the speakers are on a hifi unit.
Tony
PS, here's the Yamaha's specs
MF 2Si SPECIFICATIONS:
Tony
- Maximum Power (4 ohms, 1kHz, 0.7% THD, for Europe) 115W +115W
- Maximum Power(8 ohms, 1 kHz, 10% THD) 140W +140W
- High Dynamic Power/Channel (8/6/4/2 ohms) 125 / 150 / 165 / 180 W
- Frequency Response 0 ± 0.5 dB / 0 ± 3.0 dB
- Output power 76 watts per channel @ 8 ohms
- Output voltage 25V RMS, 20Hz to 20 kHz; onset of clipping
- 70 Volts peak to peak
- Current 25 Amps peak to peak
- Damping factor 36
- Output devices 1 pair per channel
- THD 20Hz to 20 kHz (Line-In) <0.014% typical
- Signal to noise ratio >96dB ‘A’-weighted
- Frequeny response +0, –0,1dB, 10Hz bis 20 kHz
- Inputs 6x RCA / Line Level
- Input impedance (Line-In) 40k ohms
- Pre-Out (Bi-amping, second power amp etc) 1 pair RCA
- Line-Out 1 pair RCA
- Speaker ouputs bananas, spades or bare wire
- Dimensions WxHxD 440 x 100 x 400 mm
- Weight (net / gross) 9,2 kg/ 13,0 kg
- Power connection 115-230VAC 50/60Hz
- Power consumption 320 Watt max. / 0,5 Watt standby
- Accessories remote control, mains cable IEC (10-A)
- Audiolab 6000A specs
- Type Integrated
- Number of channels 2
- Frequency Response 20Hz-20kHz (+/-0.3dB)
- Tone controls? No
- Max power output into 8 Ohms 2 x 50W (8 ohm, THD<1%)
- Max power output into 4 Ohms 2 x 75W (4 ohm, THD<1%)
