Colin Barron
My HP laptop has made a racket for months. I looked at the repair on youtube. It showed how to remove a million screw, completely strip every bit of the laptop, blow out the fan and heat sink fans to remove dust. Then hopefully put it back together. Time 2 hours plus!
Or you could cut out and bin the plastic fan cover and heat sink cover. Time taken 10 mins.
