snaphappybob
Not sure there's an answer save masking tape over the remote receiver but here goes.
I'm using a Marantz NR1510 for TV & films. This is connected via its pre outs to a Naim Nac82.
Unfortunately they both use the same remote frequencies for the volume. Normally I'd just set the 82 to 12 O'clock and use the Marantz remote do the work but unfortunately both volumes rotate so it either gets too loud or too quiet from the front speakers.
Any suggestions?
Any suggestions?
